Los33 is a noob so i need help
If you have the money don't skimp on the power. And get products you know are going to be around when you need them.
Taramp comes with warranty and probably have been out longer then soundqubed.
Could be wrong on this, but stetsom and banda have been long time companies.
And i meant soundqubed name not previous audioque.
Sent from my draconis using Tapatalk
All I'm saying is use your money wisely. Changing equipment on builds like this gets expensive and very annoying. Build it to the point you never have to worry about it. I can tell you it fells good to go to a show, crank it up and just walk away. Not to far away or **** might get jacked. But you get the point.
Suggest some amps then //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I just dont like the idea of spending 1500$ on an amp that i could get an alternative and its cheaper and last long enough to upgrade.
Quinten emailed me back that mid a August the new 2015 design of the dss ethos will be shipped out so i will be placing my order in a week.. Time till it ships out will give me enough time to prep my truck with all new wiring and batteries.
Just think about it. Those subs sell out fast right? You get a defect and he don't have anymore to replace it now you are out a sub and have a paper weight you can't use. Just stuff to think about. Saving a buck isn't always saving a buck. When getting into these kinds of builds there is a good chance you are going to break stuff at first. Buy built proof as possible. It will save you time and money before it's over.
Been thinking about what you said.
I doubt ill break anything, but if i did i would not have a replacement etho for a while.
So now new plan is junk the taramp and jump onto a Soundqubed 4500.1 so i can run it at 1 ohm.
Then possibly hdc3 18's, but if there are other 18's out there with better build times id like to know of them.
I plan to get the box going while buying the equipment instead of waiting 2 months for stuff to come in.
los33
Car Audio G
los33
Houston, TX
los33
