Looking to replace my 6.5 inch 2 ohm subwoofers. Any suggestions?
joelx21
i would just buy something like a memphis pr 10 and put it in a sealed box should run u like 150 for sub and box and maybe 50 to install it depending on where you go to install it.
and i now guys theyre plenty of options just saying one of them.
Thanks for the suggestion, but I actually need 6.5 inch subs for my side panels. My apologies for if I didn't provide enough details. Just in case, I went ahead and added some.
Yeah, I just got my amp is wired @ 2 ohms, but even the stock monsoon amp is wired at 2 ohms.
Audiopipe TSV6R 6-Inch 150W DVC Power Subwoofer $61.11 dual voice coil (With a 10% discount)
Audiopipe TSV6R 6-Inch 150W DVC Power Subwoofer : TSVR6 : $33.95 : VMInnovations.com
Autobahn AMD60Q 6-1/2" Midbass Drivers 6.5" Midwoofers 3 ohms $59.99 shipped for two
AUDIOBAHN AMD60Q 6-1/2" Midbass Drivers 6.5" Midwoofers - eBay (item 290542421893 end time Apr-05-11 20:48:45 PDT)
I also found these. Any good?
Joel
So far I have found these subs that are or can become 2 ohm subs.
Audiopipe TSV6R 6-Inch $61.11 for two (With a 10% discount)
Bazooka WF641.5DV 6.5 $99.98 for two
Bazooka WF641.5DV 6.5" Dual Voice Coil Subwoofer - eBay (item 280640804247 end time Apr-06-11 09:08:42 PDT)
KICKER 10CVT652 $116.50 for two
2 KICKER 10CVT652 CAR AUDIO 6.5" POWER SUB WOOFERS PAIR | eBay
The Audiopipe subs are only 6" versus the Bazooka and Kicker which are 6.5" each. Other than fitment issues, will this cause me a problem?
Also, are the Kicker or Bazooka that much better than the Audiopipes?
I'm not looking to go all out, I just want a better than stock sound.
Any other subs that you guys can recommend?
Thanks,
Joel
Any of these speakers are going to ultimately be more influenced by the enclosure than the actual brand. If it were me, I'd buy the one with the best build quality and actual power handling, then spend money on beefing up the enclosure around them. Hell, even deadening/stiffening the area around the actual stock speakers will make an improvement.
joelx21
joelx21
So Cal
dkdub
