Looking for the right amp for PREMIERS
Hello, i have 2 premiers champion series The TS-W3001D2 boasts top output power of 3000 W. I'll paste a review that i found on the web.
Pioneer Premier champion-level SPL subs pack power and punch. The TS-W3001D2 boasts top output power of 3000 W. This subwoofer is the perfect match for a Pioneer Premier SPL amp. High-tech materials like the newly designed voice-coil ensure the intensity you need for a real power boost. Now you can push your subwoofer to the limit with confidence: increased heat-resistance and a reinforced suspension structure, posting patent-pending technology, are backed up by a powerful double-stacked magnets motor structure for a guaranteed reliable performance. Enjoy freedom of choice in installation, with a more flexible enclosure volume. This system will justify your pride.
# 12-inch Woofer
# Voice Coil: Dual 2-Ohm
# Peak Power: 3000 Watts
# RMS Power Handling: 1000 Watts
# Frequency Response: 20Hz ~ 150Hz
# Sensitivity (Efficiency): 92 dB
# Voice Coil Diameter: 2-1/2
# Magnet Weight 110 oz
# Recommended Enclosure Size: 0.5 ~ 1 cu. Ft.
Can someone tell me the right amp for 100% operational bass?.
I already bought Hifonics monoblock class D 1,500 watt. and the bass is too low.
any recomendations? thanks
zertorer
zertorer
Dominican Republic
TurdFergueson2
