Looking for some type of wiring diagram!! Noob Installer!
Nocturnal
So this will be my first install EVER, and want to make sure I get it right.. What I'm looking for is nice easy to read wiring diagram I can follow for these items..
X4 6.5 - in all 4 doors Pioneer TS-A1682R (currently installed)
X1 Pioneer DEH-P6900UB (currently installed)
X1 Kicker zx650.4
X1 Kicker zx750.1
X1 KICKER VS10L7 10" SOLO BARIC L7 SUB BOX ENCLOSURE 2 ohm
So its just the amps and Sub I need to install.. Also looking for a list of all the accessories I will need for the job (wiring etc.)...
Any help would be greatly appreciated!!
Wire strippers. channellock/visegrip/pliers. Drill. screws. adjustable C wrench. Alan wrenches (probly came with the amp).
RCA cables, Ground wire/Power wire, speaker wire. Fuses. Wire terminals.
Where are you mounting your amps? May need MDF for that.
Im probly forgetting stuff.
2000 Dodge Darango
I checked out those sites, could not find anything about wiring 2 amps..
Im pretty sure he was joking.
Also, you need a wire and wire distributor for your remote wire. You could just daisy chain them.
Im still not sure what you are getting at with the wiring diagram for your amps.
heres the one for your sub.
http://mobile.jlaudio.com/support_pages.php?page_id=160
You have plenty of space to mount those amps anywhere, why under the seats?
I was able to find a nice diagram on Crutchfeild, that I can somewhat understand.. But I am 1000% noob lol!! Couple of the things I dont understand is, do I have to connect the 2 amps together in some way? Or do I have 2 run 2 sets of RCA's to my head unit? What does this distributor do? Do they come with the Duel Amp wiring kits?
Also the 4 speakers I am looking to amplify are all door speakers. Is it going to be a HUGH pain trying to run speaker wire from each speaker?
As far as a mounting place I have no idea what im doing as of yet. My Durango has a 3rd row seat which I don't think I'll ever use, but I still want to leave room to haul stuff if needed.
Here is the diagram I found:
They dont have to be, but those amps should have an input and output place for your RCA cables. It would save you a few dollars on RCA cables, and time running a separate set. Just run RCAs from one amp to the other.
Nocturnal
Nocturnal
Gilbert, MN
Chevillac
