looking for some noob advice
hellz
Hello everyone.
so, like the title says, im looking for a little advice.
i have a 03' Hummer H2 with the Bose system
i replaced the HU with a Pioneer AVH - P4000DVD that is connected to the BOSE amp and stock BOSE speakers that are failing.
Pioneer AVH-P4000DVD DVD receiver at Crutchfield.com
6.5 componete speakers in the front
6.5 - 2 ways in back doors
there is also a 5 or 6 inch "sub" hidden somewhere in my dash.. anyways...
i would like to remove all traces of the BOSE system.
replace the front stage area with decent speakers (Component)
i would like back fill speakers for the rear seat area.
Budget is $500 for atleast front speakers, and a Amp.
what can you guys recommend?
i listen mostly to Rock music, but with some techno, and rap thrown in there.
if the song has bass in it, i want to know its there!
below is the following items i have, but not installed. not sure if any of it is really worthwhile actually, but i got most of it for free, so cant complain.
SUBS~
ROCKFORD FOSGATE P210S4 10" SUBWOOFER
Sensitivity: 85.8 dB
Frequency Response 20-200 Hz
Recommended RMS Power: 200W
Peak Power Handling: 400W
Impedance: 4 ohms
Pioneer TS-SW301 12in 4-Ohm 250-Watt Subwoofer With Shallow Mount Design
Product Features
1000W maximum power handling (250W RMS)
Composite IMPP with interlaced carbon fiber cone
Includes a small mount design for tight spaces
Flat subwoofer uses air suspension system to provide clear, powerful bass
Impedence: 4 ohms
AMP~
2010 NEW! 4 CH 4000 WATT CAR AUDIO AMP AMPLIFIER AMPS
PLA4478
RMS Power @ 4 Ohms: 4x200 W
RMS Power @ 2 Ohms: 4x320 W
Bridgeable RMS Power @ 4 Ohms: 2x2000 W
Maximum Power Output 4 x 1000W
4 Channel Bridgeable MOSFET Amplifier
Frequency Response 20 Hz-50kHz (±3dB)
Output Power @ 14.4v DC, 50Hz
2 Ohm Stable
MOSFET Power Supply
PWM ( Pulse-Width-Modulation ) System
Glass Epoxy PCB
Silver RCA Inputs
Custom Terminal Block for Speaker Connection
Thermal / Overload / Short Circuit Protection
Input Impedance: 47K Ohms
Soft Turn On/ Off
Advanced Protection Circuitry
S/N Ratio: >90dB
Dimensions:10.24''W x 2.21''H x 17.72''L
6.5 Comp Speakers~
PYLE PLG6C
Standard 6.5" Sizes Fits OEM Locations
Yellow Color Poly Injected Cone
Non-Fatiguing Butyl Rubber Surround
High Temperature Aluminum Voice Coil
Yellow Coated Steel Basket
40 oz. Magnet Structure
Rubber Magnet Cover
200 Watts RMS/ 400 Watts Peak
Frequency Response: 50-5KHz
Impedance: 4 OhmsOne Pair 1" Neodymium Dome Tweeter:
1" Silk Dome Neodymium Magnet Tweeter
3 Mounting Options: Flush / Swivel / Surface/Angle
Frequency Response: 1.4-24KHz
Impedance: 4 Ohms
One Pair Passive Crossover Network:
2-Way passive Crossovers
12dB Octave SlopeAccessories:
i thought about using the Amp for some 6.5s, but at 200 RMS, wouldnt that be overkill for most good quality 6.5s out there?
most i have seen are 50 to 75 RMS, that max out at 100 to 200w.
wouldnt this amp be too strong for even those pyle 6.5s? 200rms/400w?
just by word of mouth really, but arent they named "pile" for a reason?
if anything, i was thinking of using the amp for the 12" sub..
but then again, im not even remotely a expert on car audio. i just barely know enough to confuse myself.
thanks, for the info and help btw
what if i do not use the Pyle speakers, and decide on using something along the lines of these:
Focal
Focal 165A1 6 1/2" Component Speaker System NIB NR : eBay Motors (item 230465017007 end time Apr-28-10 07:44:31 PDT)
orthese JBL
JBL
i understand turning the gain down on the amp, but wouldnt it still be overkill for these speakers since they are only 50 to 70 RMS?
for what i always understood was that RMS = continous power at all times. you could turn the gain down to 0, and it will still put out the RMS rating per channel?
im not looking for a competition setup, but not looking for ghetto either. so if i need to buy a new amp, thats fine.. just looking for recommendations.
but if this amp will work, hey it saves money for other goodies. im not ignoring any advice, i just dont know, so sorry about the questions.
thanks again!
hellz
hellz
Burnsville,mn
hellz
