Looking for some knowledgeable advice
Guitarplayer546
Well I am looking to up my game in my car as I currently have stock deck/speakers in my 03 mazda protege5 and I am looking to get some sub's.
My I have been looking around on a few websites and other then watt's I don't really understand all that much. I am looking for a amp that is med-high quality for a reasonable price. I listen to mostly metal/rock with a bit of ska/rap on the side. So in terms of the actual speaker size what would you suggest? and brands etc? a full name would be appreciated so I could look it up to get more information.
Also whats a decent range in terms of watts? I saw http://www2.visions.ca/catalogue/category/Details.aspx?categoryId=29&productId=854&menuId=1&parentId1=27&parentId2=''&parentId3=''&menuLevel=2
which seems pretty decent, 800 watts should be plenty eh? I was thinking of either a 800 watt amp or 2 600's, would there be a large difference?
Thanks for any help you can provide. I don't want to go into the store and look like a total dink so they can try to sell me shit i don't need.
wow could you be any more vague? lol
so how about a budget maybe? Are you looking to get a new deck too?
how much room are we working with? speaker size doesn't change how something sounds for ska / rap or any other type of music, so go with the largest size that you want / can fit.
i'd personally find a sub first, and then go from there for the amp (within budget).
plus you need either the parts for the box, or the cash to have someone build you one, along with wiring.
Ok well in terms of budget total I am looking to spend under 1,000 for everything, deck/subs/amp
Now I am not sure what exactly i should get. I am indeed looking at an amp first. I am thinking of something like this
http://www2.visions.ca/catalogue/category/Details.aspx?menuId=1&categoryId=1&productId=854
what I guess I am confused about is the actual spec's, like
800W Peak / 400W RMS and its independance 2ohms?
So like the sub itself outputs 800watts, the amp i need has to be specifically for something for 800 watts right?
I was also tihnking of 2 10's that were 600each. would the 2 10's sound quite a bit louder then the single 800 watt?
Sorry I may seem vague with the questions, but i don't know much to begin with for this stuff yet. thanks
it will hit RMS 800 at a 2 ohm load which means your entire ohm load will have to be 2 ohms so you take what ohm your subs are and add them up and divide by the amount of subs you ahve and thats you ohm load try to stay away from 1 ohm becuz its usually not stable if you need anymore help PM me
Guitarplayer546
Guitarplayer546
Canada
Guitarplayer546
