Looking for some advice on my build
Straxxus
Professional lurker
I'm just going to get right into it, here's my setup:
Scosche 600 watt wiring kit from walmart (8-ish gauge wire, 50 amp fuse)
Crunch powerzone "1800 watt" 2 channel amp
1 pyle blue label 12" 800w max
1 Pyle blue label 10" 600w max
Custom box
First question, is my amp any good? I'm not familiar with crunch, so I dont really know what to expect out of it. I've had it for about a month now and it seems to be working pretty good, but it gets pretty hot. However I'll address that in a moment.
Second, how bad is it to connect a 2 ohm load to an amp that says not to go below 4 when bridged?(thinking this is where the heat is coming from)
And lastly, a bit controversial from what I've read; would aa capacitor keep my lights from dimming when the bass hits? I'm only running around 500 watts, I don't think that's enough to dim the lights, maybe a new battery is in order?
The subs are junk. Shouldn't mix sizes to , the amp is very low end but can work for you depending on your needs. 2 ohms bridged is bad. It will make your amp eventually blow Get a new kit. And ditch the cap. Do the big 3 instead
Yeah I didn't expect the moon from $25 subs but hey, this is build #1 , nowhere to go but up. Also I don't have a cap, was debating on it until I saw how many people were disappointed in them. Thanks for giving me a verdict on that. As far as mixing sizes goes, I probably won't do it again. Good to know my amp is junk so I don't feel so bad abusing it lol, I got it for like $40 off of craigslist so that's probably what it's worth. Big 3 is on my list, just need to get past the holiday season so I can buy things again.
Straxxus
Professional lurker
Straxxus
Fernley, NV
tyronekndrck
