Looking for first amp
ksauers
21stCenturySchizoidMan
Looking for an amp for front stage. Choices: Sundown 100.2,Eclipse EA2000,XA2000, USamps XT800.2 or Audison Srx2. Need a basic sq amp simple to use. I'm a newb and just want to listen to good sq music. I have a ford f150 supercab with everthing stock. Will there be any problems hooking one of these up just the way the truck is? How much space do you need? I have 15 x10 under rear seat. How much space do you need to allow for wires n such?
i like the eclipse's and us amps. clean sounding amps. the audison can be a pain to wire up. and your truck stock electrical should be fine, although i would up grade the ground wire on yourt batt. ford for some reason put a small wire for that.
6spd had suggested Eclipse. XA is d class,EA is A/b. What's the difference? Or none I should worry about? Either better for front comps?
VERY happy with the Sundown driving my subs, so I'd recommend their comp amp. Plan on getting one for the next build I do //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
ksauers
ksauers
Milw. Wisc.
azbass
    Jun 24, 2026
    Jun 24, 2026
