Looking For An Amp HELP
Hi, The amp im using currently isn't stable for my subs.I have 2 MTX Terminator 12"s and theyre 2 ohms. 400 rms at 2ohms. 1200 watt total?
What kind of amp do you recommend? I wanna stay under $75
I assume you mean they are single voice coil at 2 ohms and w/ having 2 of them wired at 1 ohm total load, your amp isn't stable at that.
If the subs are 400rms, then you want 800rms. For $75.00 there is not that many choices. I could point you in the direction of a pretty clean and decent amp that does close to the ratings for $99.00, but that's the least you can get away w/ spending. The Precision Power Black ice 650.1 class d amp can be had for $99.00 if you search google for it. For that amount you won't find really any amps that will put out claimed power, or even clean power. But this one will get you pretty close to what your looking for, and it's brand new. Or you can hunt c-list and hope to catch someone down on their luck. Hope this help.
dylanmurphy23
dylanmurphy23
Mankato, Minnesota
lex2674
