Looking for amp 1200-2000rms, $300 whatcha got?
A used Soundqubed 2200 is right on the money.
keep on the lookout on the classifieds
Thanks. I was planning on the new soundqubed 1200.2 coming out, but I emailed them and its $469, kind of a major jump from the q1-1200 being $269. I thought low price good quality was their thing?
It didn't really have any specs. Does it do rated? How many watts at 1 ohm? Cea compliant?
does a little more than rated, CEA doesn't mean much, its only a test to see if it does power at 4 ohm, not 1 ohm or 2 ohm so completely and utterly useless unless you are looking at 4 channels. Mine hifonics is CEA compliant but that phoenix gold is better build quality and puts out more power than what its rated for.
What is it rated at? I didn't see anything from the link. Couldn't find it on amazon either. I didn't want to assume its 1200 just because it's in the model number.
http://www.phoenixgold.com/products/amplifiers/SX/product.php?productID=105
Frequency Response: ± 1dB from 20Hz to 300Hz
Signal to Noise Ratio: >90dB
Low Pass Crossover: 12dB per octave
Subsonic Filter: 12dB per octave
Low Pass Crossover Range: 30Hz to 300Hz
Subsonic Crossover Range: 10Hz to 55Hz
Bass Boost @ 45Hz: 0 to +18dB
Low Level Input Range: 200 millivolts to 8 volts
Lowest Recommend Load: 1 ohms
Typical Efficiency: 80%
Damping Factor: Greater than 200
Continuous RMS Power 14.4Vdc ≤ 1% THD
1200 x 1 @ 1 ohm
800 x 1 @ 2 ohms
Recommended Fuse Size: 60 amp
Power/Ground Wire Size: 4 Gauge
Dimensions (Includes Mounting Feet):
12.3” L x 6.9” W x 2.0” H
I have an Elemental Designs Nine.1 Im selling for 205 shipped. Minty condition. Probably won't find one in this condition. Gonna post it on the classifieds soon
Amp does 1200 rms at 12.5v and around 1500 at 14.4v
HELLA efficient. I had less voltage drop from this amp than I did with a Soundqubed 750.1. Amp is beastly and sounds beautiful
SX1200.1 - 1200 Watt Mono Amplifier - Phoenix Gold
1200 x 1 @ 1 ohm
800 x 1 @ 2 ohms
Thank you. Will my 4g ofc I have installed work with this?
95lincdog
95lincdog
portland, OR
Sqall12001
