Looking for advice on how to wire this set up
I have two audiobahn aw1200q's dual voice coil specs are 350w rms per coil peak handling of 1400w at 4 ohm each sub its bein ran by a 2500 watt .5 ohm capable amp 2 channel what ohm should I be running these at
Run these in parallel and you should have 1 Ohm, that is the lowest you can go unless you have 2 Ohm DVC subs, which would go down to 0.5 Ohm in parallel.
USMCJM6092
USMCJM6092
Greensboro PA
dubstepper1000
