Usually 50% or more is lost - typically you will have about 2x rise (wiring to 1 ohm, you will see about 2 ohm minimum since it's a reactive load)Would 2 12s Sundown SA or Type R's be good on the FSD2600. And is it true you loose about 30% of power due to box rise and voltage drop? Or is it less %?
Type Rs arent in the same league as sundown in terms of loudness capabilities, not even close. They are much more fragile too. Their power rating is 1000 watts before rise as in, 1000 watts after rise, they will fry. Tested a lot and they just dont even come close to most of the other subs on the market. Higher RMS does not always mean louder. The alpine is a good bit lighter than the sundown as well..Would 2 12s Sundown SA or Type R's be good on the FSD2600. And is it true you loose about 30% of power due to box rise and voltage drop? Or is it less %?
i really like them as well. nothing highend but a great bargin..I have the xtr and it is solid.
Agreed. Not a barn burner but it gets the job done quite well.i really like them as well. nothing highend but a great bargin..Im hoping hte HCCAs are like hte orginal with the high dampening factors and good isolation on between switching and power supplies..
the mms is pretty high.Type Rs arent in the same league as sundown in terms of loudness capabilities, not even close. They are much more fragile too. Their power rating is 1000 watts before rise as in, 1000 watts after rise, they will fry. Tested a lot and they just dont even come close to most of the other subs on the market. Higher RMS does not always mean louder. The alpine is a good bit lighter than the sundown as well..
This is the Audio legion sub soundrive was talking about. They look pretty decent and beefy for the price. Lots of cooling, strong sundown style basket
Audio Legion S2512 12" 700W RMS Subwoofer - SounDrive Audio Store
i love high power installs and turth be told most amps today have 200-300 damping factor which driving one woof isnt bad. i love to see the higher damping factor amps though.Agreed. Not a barn burner but it gets the job done quite well.
Sent from my SCH-I605 using Tapatalk
I'd love to run a jbl crowni love high power installs and turth be told most amps today have 200-300 damping factor which driving one woof isnt bad. i love to see the higher damping factor amps though.
