Looking for 2-12" 4 ohm DVC's
LIGHTBEING
OK guys, I have my amp picked out. It's the Soundstream TR1600/2. If I bridge the amp it will pump 1600 watts at 4 ohms so know I need two 4ohm DVC woofers....right? and then wire it like so:
I was first interested in the L7's but I think I want something with more SQ. I then became interested in the Magnum D2's only to find out they come in 2 ohm. Maybe 2 RE SE's.........they are 600 RMS each and I would be pumping 800 watts into each which I'm sure they can handle. How do you think this will sound?
Any other suggestions for 4 ohm DVC's
How much are the 12" SE's?
and how would they compare to the L7's?
DCR = DC Resistance
Yes, it means 4-ohm per coil, so you could either wire the 2 coils in series for an 8-ohm load, or in parallel for a 2-ohm load. If you had 2 subs that were 4-ohm DVC, then you could wire both to a 4-ohm load.
Anyone????
How are the SE's? How would they compare to the L7's?
Do I have this right, they are only $169 each? That's pretty cheap. Do you get what you pay for in this situation, or more?
LIGHTBEING
LIGHTBEING
New Jersey
Norcalracer283
