LOC wiring and subwoofer plays randomly
devinsierra90
I have a 2014 honda accord ex-l and hooked up my sub/amp with an LOC. The sub and amp combo work and play with music but the issue is the subwoofer will start playing one note continuously at random points and wont stop for like 10 seconds whether I have music turned on or not. I tried googling and searching but I wasn't even sure what to search for to be honest.
Any help appreciated
About a week ago, another user had the exact same issue which yielded no solution. Still expecting an update after he performs troubleshooting tips advised by this community.
As for yours, let us try disconnecting the RCAs at the amp and turn on the system. If the issue persists, another user suggested using an alternate power source, like a second battery connected only to the amp. Let us know the results.
I have had this happen in the past. Soundstream Rubicon 2500. It was a bad internal problem with the amplifier
I've heard this happen with a Hifonics, Skar, MBquart, and Belva amp.
Wiring was all correct. Amps all took a dive.
The hifonics 2400 was totally off the wall, it would fire 100% of it's power into the sub in short quick bursts. o_O
I've heard this happen with Hifonics, Skar, MBquart, and Belva amp.
Not so much Skar. Usually if you get a bad skar, it just wont work right out of the box. Or it will pop the magic smoke.
Yeah tapping off the 4 gauge is typically fine. However, you need to fuse the smaller wire right by the 4 gauge at 1 amp (or whatever the small...
780
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
589
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
unfortunately no empties but a couple promising choices, out of town right now have to this weekend 1) Car Radio Switch, Climate Control System...
devinsierra90
devinsierra90
AnthonyO
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
