LOC to stock headunit wiring question.
  • 2
beauml
so, i am next one to questioning about this...
i found out that i need line output converter to convert high output into low output for aftermarket amp?
and LOC needs to be connected to either front or rear existing speakers. (front or rear? some says front has full range, but some insist to do on fronts)
i was wondering if it just needed to be soldered onto (or tapped into) the terminals of each speakers, why cant it be attached or inserted to connector on the back of head unit? looks like i can get the diagram for which goes for which. can i just share that little hole?
what loc brand are reliable? can i get boss? metra? scosche slc4?
i dont have money for some over 100 buck units.. i can get them for like 20 for the most.
or is it good idea to get something like this?
Audiobaxics AA HON1729 Honda Add An Amp Amplifier Adapter Interface | eBay
im planning on adding just one subwoofer and a amp from kicker.
i have cr-v 2012 lx basic model.
i want to do least damage to the car. i might have to sell it you know.
thank you!
LOC's can be had for literally $10, now the quality of that may be suspect however. Since you said you're budget is about $20, I don't have an exact one to recommend to you.
LOC's are very easy to connect, you can simply tap into the +/- of the audio output, or you can solder it (there are other options also).
Suppose you had a head unit made by company X (assuming this is aftermarket). You wanted to connect the LOC to your rear deck speaker for a subwoofer install. You'd find out what is the +/- of the stock speaker input and tap into those wires accordingly. Take the +/- you just tapped into, and match that to the +/- of the channel that you want on the LOC (assuming this is a 2 channel LOC).
Be warned though, you pay for what you get..
so, sharing slots on connector idea is not a vaild thing to do?
and when i do tapping thing, i would have to total of 4 wires right? +/- from right rear and left rear? and ground too.
if budget was 50 would that make different?
I've only used the Audiocontrol LOC's, and they are around $75+, you probably won't need to ground a normal LOC.
When you wire tap, yes, you're connecting 4 wires.
audiocontrol lc6i?
is it worth investing? probably.. that was stupid..
hmmm i guess now i have to go buy more speaker wires for tapping purpose, cause they only give you like four 3 inches long wires on cheapos.
493
Yeah tapping off the 4 gauge is typically fine. However, you need to fuse the smaller wire right by the 4 gauge at 1 amp (or whatever the small...
904
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
828
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
beauml
beauml
Dallas, TX
beauml
