LOC output-9.5v Amp input 4v
butterMilk
BC
I have a LC6I I am going to be using, says it will put out 9.5v (rms)
JL xd 400/4 will accept 4v. But it also says the amp will accept speaker level signals.
Is this something I should be worried about? I can keep the LC6I turned down, or even use a DMM to set it?
But I would like to keep the LC6I turned up, because it says that is best!
Yeah so I can keep the LOC turned up, and then the gain on the amp will be set low?
I just don't want to damage the amp.
Read the manual on the LOC. Audiocontrol's stuff usually has complete install / adjustment procedures. Typically you set the amp sensitivity to some midpoint and use the level controls on the LOC to match gains. You don't crank it to full 9.5V output.
92
Looking to buy and install an LOC. I got the basic functionality of it but not sure what I need. My set up is a factory Impala stock radio, 4...
Yeah tapping off the 4 gauge is typically fine. However, you need to fuse the smaller wire right by the 4 gauge at 1 amp (or whatever the small...
821
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
663
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
butterMilk
butterMilk
BC
maylar
    May 16, 2024
    May 16, 2024
