little help please
  • 2
matt31
hey i drive a 1994 ranger extended cab and just bought a 12" RF HE2 and i dont want to take up the whole back area of my truck cuz i have to take ppl with me sometimes so i was just gonna put it behind the drivers seat, BUT i dont kno dimensions to use to make the box?? which direction to point the sub?? or if i need a wedge box or if i can make a rectangle or square box instead?? the only thing i do kno is that i want the box to be sealed...if someone could help out on ne of those questions it would help me out A LOT...thanks
first, go to rockfords website cause i hear they have some good tech advice. second i found that a sealed rectangular box with subs facing away from the driver close to a wall make a really good sound. hope this helps
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
12
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
170
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
456
matt31
matt31
richmond,MO
richie1
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
