Line output convertor question
Okay this may be a dumb question but its just a thought. I got a line output convertor and its 12v. And the amp I got says this:
RMS Power Rating (14.4V):
580 Watt x 1 Channel @ 4 Ohm
725 Watt x 1 Channel @ 2 Ohm
1000 Watt x 1 Channel @ 1 Ohm
RMS Power Rating (12V)
395 Watt x 1 Channel @ 4 Ohm
525 Watt x 1 Channel @ 2 Ohm
785 Watt x 1 Channel @ 1 Ohm
So does this mean that I will only get what the 12v ratings are or what?
NO
The 12V on your line output converter means it needs 12 Volts to turn on.
The ratings of your amp are based on how much voltage you are supplying your amp with from your charging system/battery/batteries.
Curtonamis
Curtonamis
Wichita, Kansas
Curtonamis
