Line Output Converter using 1 ch only?
bussle
Hi guys,
I just installed a 2 channel LOC in my new wrangler to feed my mono amp for the 2 12"s. I spliced all 4 wires leading from my stock HU to the factory sub (dual coil).
On the LOC, I can adjust each channel separat.
Would you recommend to use only 1 channel from the LOC plugging in a rca splitter? (Meaning 1 rca into the LOC splitting to 2 rca going into the amp)
The advantage is to have the same input on both channels at the amp. Right now, this signal could be different at the amp input if I do not hit exact the same adjustment on the both LOC knobs.
I hope, you can follow my theory //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif . As you can see, English is not my first language... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Thanks,
Alex
bussle
bussle
Detroit
jco1385
