Line out converter for stock stereo
11se-r11
i have an 07 nissan sentra se-r and i want to install an amp to run subs off of the factory deck.. I know i need i think its called a lineout converter to wire from the back of the stock deck but im not sure how to do it. Does anyone know a good site that maps this out for me? or is gifted at giving clear intructions...
Get the PAC SNI-35.
From PAC-Audio.com:
SNI-35 converts 2 to 40 watts per channel speaker level output into a pre-amp signal. Perfect when adding an amplifier to a factory or aftermarket radio. Great for getting an additional set of pre-amps outputs from a head unit equipped with only one set.
That is what I used to hook up an amp to my stock headunit. You splice your stock speaker wires and the wires coming off the module. Very easy install; fairly decent quality. An aftermarket headunit would be best, but this SNI-35 works good.
http://www.pac-audio.com/products/productsCatagory.asp?mmSearch=Adding-An-Amplifier#SNI-35
11se-r11
11se-r11
Chicopee, MA
rod_b
