Line Converter Removal?
mgraziano
So I had a local place install my amps. A moment of weakness, I think.
Anyway, they used line out converters b/c my Alpine amps did not have speaker level inputs, and the Nissan factory Panasonic (Rockford Fosgate) head unit did not have line level outs.
Now, I installed a McIntosh head unit that does not have speaker level outs, only line level. Do I have to remove the line out converters, or can I simply turn up the gain on them all the way? The line out converters are model PAC SNI35. I wasn't able to find out if maximum gain is a 1:1 ratio.
Thanks,
Michael
'04 Nissan Frontier CC
Thanks,
Michael
Why not take out the line level converters completely and run rcas from the H/U?
Just trying to save hassle. That, and when I eventually sell the truck I'll put the factory HU back in, which will need the line converters. yes, I guess I can reinstall them later.
like I said, hassle. If the maximum gain is 1:1, it'll be all that work for nothing.
-Mike
-Mike
It may be a little more work but IMO it is the proper way, I was never a fan of line level converters. But it's your truck.
The definitive answer. Maximum gain on a PAC SNI35 is no-where close to 1:1. If you switch from a speaker lever output to a line level output HU, then you must remove your line converters.
-Mike
mgraziano
mgraziano
Austin, TX
mgraziano
