Light wont go off...
  • 4
khi
¤ Iñdi° Møâñin ¤
Whassap all.
i got ma amp in my Pathfinder, and my amp, for some reason, the protection indicator light wont off, and the amp wont work, i brought the amp in the house, and it works fine (i ran it ona ac/dc converter....)
any ideas of whats wrong??
\thanx
Probably a blown fuse or a shorted wire. Check fuses in the amp and near the battery. Check all wiring for shorts. Your battery should put out between 11-16 volts.
Many amps can't handle loads below 2 or 4 ohms and may shut down as a result.
Yeah as said above you have to get clean connections between points, ground is especialy important. You might also check if your battery terminals are corroded and if so clean them well and go get some anti-oxidizing spray at your local auto store, they may call it like battery terminal cleaner or something like that but it's all the same.
make sure there are no speaker wires touching + to - this will make it
go into protection mode and if they're touching all the time it wont
allow it to work
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
804
I am not well versed in box design, so I do not know outcomes based on over/under sizing. The one thing I do know is that too big of a port will...
782
Big subs have heavy cones. Heavy cones plus high power requires solid anchoring and solid enclosures. Most people don't anchor their boxes to the...
16
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
khi
¤ Iñdi° Møâñin ¤
khi
Calgary, AB
rsflores
    May 31, 2024
    May 24, 2024
