Lets SEE your FiberGlass SUB BOX
1BadHawk
Here
Ive gone through all the stickys, and seen some prety cool glassing projects. I almost feel like a pro at it and I havent even made one my self //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Only thing is, most of the ones pictured are for kick panels.
Anyone have any larger sub boxes theyve done or seen, that youcan post pics of?
From my Cougar: Simple & Sweet.
Sorry to jack the thread but do you have to have it basically perfect before you start to lay bondo, in order to paint? Because mine glass project had waves in it even though I layed bondo down. I never really did keep on trying after that...
Bondo is for fixing imperfections. If there are waves in your box, you did not work the bondo properly. It takes a lot of time to get something to look flawless. Also, Hi build primer is your best friend. Use it to fix scratches, pinholes and other minor flaws and then just wetsand smooth.
Its nothing special. First box i made with fiberglass. I still hit 146.8 with it though.
Never painted it. Its a good thing too cause i think theres a crack in it.
Time for a new one. New subs too.
Yeah I just kind of gave up on the bondo issue....
I heard High Build primer was the way to go. It's easy to sand off and you can get it around 1/4" thick...
Yes nice and clean, with some steathlyness to it. nice detail around the amp.
can still use your trunk. always a plus.
what brand of high build primer you use and about whats the price?
do you get yours in the gallon form?
jamie
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
6
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
455
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
475
1BadHawk
1BadHawk
Here
hidden_ghost_03
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
