Lets see your acura cl system set up
  • 4
I have a 2001 so my trunk might be a little diferent but here are some of my setups. Not the best of equipment but they all did what they were meant to do.
Punch P2 in a Q-logic ported box
Two 12" older type-r's in a sealed Q-logic box 1.25 per chamber
Two JL W0's in some crap prefab sealed box and these almost did as good as the 2 type-r's
My current setup Punch 360.2 and a 10" type-r in a ground shaker ported box.
And last my Sony head unit and my Coustic 7 band EQ
**** 18's in a CL trunk I have got to see that. Make sure you post pics if and when it's all said and done.
That's funny that my cap bothers you because I don't mind it one bit. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Are you planning on upgrading the alternator and add extra batteries?
811
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
😩 😩 😩 😩 😩 That deff sounds like azz man. Id run another ground wire from the HU to a good solid ground location cleaned off and bolted down.Id use...
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
138
on1wheel01
Bang A Lang
on1wheel01
Mooresville nc
on1wheel01
    May 24, 2024
    May 23, 2024
