Lanzar OPTI70001D
subzero
Are these amps legit in the claim, do they do rated or more than rated? Lanzar OPTI7001D 7000W Monoblock Class D OptiDrive Power Car Amplifier/Amp 68889014617 | eBay
OptiDrive Series Monoblock Class D Car Amplifier
RMS Power Rating:
4 ohms: 1600 watts x 1 chan.
2 ohms: 3070 watts x 1 chan.
1 ohm: 5180 watts x 1 chan.
0.5 Ohm: 7000 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
Wired remote bass level control included
LED power (green) and protect (red) indicators
Variable Bass Boost (0 to +18 dB)
Soft Start Turn-on
Double sided Epoxy PCB circuit board
Mono channel operation
3-Way System Protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Gold-plated RCA level inputs
Custom Terminal Block for speaker connections
Input sensitivity:
Low level: 200V-8V
Variable low-pass filter (50-150 Hz, 24 dB/octave)
Subsonic filter (15-40 Hz, 24 dB/octave)
Phase Shift: 0-180°
Damping factor: >400 @ 20Hz/4 ohms
Frequency response: 15-250 Hz
Yeah that's one thing I've noticed too. Are they using different build houses on the two I guess you would call different series of Opti's? Some many similar sizes but way different RMS ratings makes me wonder what exactly is the deal behind that.
I wonder if this amp will put out more power at 1 ohm with a higher voltage. are these ratings on 12v or 14.4? Do you guys think this will put out more than two Kicker zx2500.1???
subzero
subzero
Chandler, AZ
subzero
