Lanzar Opti3201D running at .25 ohm question
eenyuheye8o8
I was wondering is it safe to run it at .25 ohm. I bought 2 brand new RE audio SXXv2s and it supposed to be dual 2 ohm but apparently it reads .8 ohm each speaker so its Dual 1 ohm subs. So im stuck either running at 1 ohm or .25. Im running 2 Engergizer Group 31 batteries, which ive learned its 2 Johnson Control Group 31 AGM batteries. Got a voltmeter in the front for the batteries. Also got a 200 Amp excessive amperage alternator. Would it be ok to run it at .25 ohm?
Battery Specs
Specs on the amp
820W RMS x 1 @ 4-Ohm
150W RMS x 1 @ 2-Ohm
2100W RMS x 1 @ 1-Ohm
3200W RMS x 1 @ .5-Ohm
General Features
THD 4ohm Power 0.5%
0.5 ohm Stable
Frequency Response: 10Hz-250Hz
S/N Ratio (4 ohm ): 90dB
Variable subsonic: 15Hz-45Hz
Phase shift: 0~180 degrees
Variable LPF: 50Hz~250Hz
Variable Bass freq: 21Hz~80Hz
Variable Bass Boost: 16dB
Source Voltage: 9 - 18VDC
Line In & Line Out
Strap two amps together for twice the power
Nickel-plated RCA connectors & Screw terminals
Thermal, Over load & Speaker short protection
Double Side Epoxy PCB Circuit Board
Power & Protection LED Indicators
Remote subwoofer Level control
Soft Turn-on/Turn-off
Dimensions : 10.63''(W) x 2.12''(H) x 19.68''(L)
Weight: 21.9
From what I can find, those subs weren't offered as d1's.
I would like to think RE knows how a nom 2 ohm voice coil should behave. A resting DC resistance of .8 ohms doesn't necessarily mean it will operate at a similarly low impedance.
You might email RE about the issue. It would be interesting to hear their take.
From what I can find, those subs weren't offered as d1's.I would like to think RE knows how a nom 2 ohm voice coil should behave. A resting DC resistance of .8 ohms doesn't necessarily mean it will operate at a similarly low impedance.
Yeah I did email them but haven't heard a response back yet. It ***** basically. I wanted D2s that's why I picked up the lanzar optis. And then boom fail.
eenyuheye8o8
eenyuheye8o8
Mililani, Hawaii
eenyuheye8o8
