Lanzar opti series amps
teptepley1
Has anyone used any of these amps?
Im looking at these 2 specifically
Lanzar OPTI4000D (opti-4000d) Monoblock Class D OptiDrive Amplifier
Lanzar OPTI3500D (opti-3500d) Monoblock Class D OptiDrive Amplifier
Are they true to rating, reliable, how's sound quality, things like that.
I would be using it to power a 12" re audio xxx at 4 ohms going for a really clean sounding, high power SQL build so if i can believe the rating, that's pretty close to perfect.
Otherwise, any suggestions of trusted amps known to put out 1600+ rms at 4 ohms?
I have had direct experience setting up systems for peeps with the opti amps - Good bang for the buck and pretty reliable, but if you are after SQ rather than SPL I'm not sure if I'd go with one of these. They will do rated or close to rated from what I've seen, but they are geared more towards going down way low in impedance while producing descent power to slam some power hungry subs than they are for an SQ install... Just my .02 ;-)
If I was building an SQ setup I'd go with an Audison, But that's just ME... I'm sure there ar going to be MANY differences of opinion on this subject LOL - Close to what you are looking for spec wise would be like an Audison Thesis Series: TH due
From their site about:
TH due
The Thesis TH amplifiers are manufactured using state-of-the-art analog and digital technology. Class A amplification stage, multi-standard analog and digital inputs and the control of the amplifier through a microprocessor make this product the most evolved among the Audison range.
TH due is a bridgeable stereo amplifier: a logical choice and natural partner for systems where versatility, power and quality are the main parameters.
Power Output
Load Imp Mono Stereo
Dual Power - Hi-current 4 Ohm 1000 W x 1 300 W x 2
2 Ohm 1500 W x 1 500 W x 2
1 Ohm - 750 W x 2
Dual Power - A Class 4 Ohm - 80 W x 2
teptepley1
teptepley1
Lake county, OH
Dirtrider4eva
