L7 vs. Type R
if along the same line, and smaller box is needed, look at the CVX 10"....then about 1.0 sealed, per driver...that'll help in small trunks //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
defiantly SQ over SPL. Its going into a small car so it doenst have to be crazy loud. Ive looked everywhere for info on the FI Q but havnt found anywhere to buy it.
EDIT: I guess you can buy them straight off the FI site. If I was gonna run 2 10's/12's should I get Duel 1 or Duel 2 ohms. Someone wanna explain what that means?
i wouldnt suggest type r or l7 for a SQ setup. I would recommend the IDQv.3 over anything for SQ honestly. Just get one 10" image dynamics IDQv.3 send it 600rms in a recommended sealed box and you will be set for what you want man i promise.
Sure,
The Duel you are referring to means that there are two voice coils (two + - terminals). If it is a DVC "2 ohm" that means there are two + - terminals and that both present a 2 ohm load to an amplifier. You can therefore wire these (through how you can connect the two voice coils) either at 1 ohm, 2 ohm, or 4 ohm. 1 ohm stable amps are rare & expensive so you generally don't want to go that route being a semi-beginner. 4 ohms is ok and stable but it gives you less wattage. 2 ohms connected to a mono amp capable of handling 2 ohms should be the perfect solution here.
honestly there's a lot to explain so if you want to message me on AIM if you have it my username is Shammiester and i would be glad to help you out
you are definitely correct in listening to us and choosing the Fi Q or ID Q, you honestly can't go wrong and you will probably blow your friends away with how clean they sound compared to the best buy stuff. in case you don't shoot me a message and don't get a whole lot of help, you want to pick 2 DVC 2 ohm subs so that you can wire them both up to a class d mono amp at 2 ohms (a certain way which i can explain later). then you need a decent class d monoblock amp to give each approx. 500 RMS, that's 1000RMS total. this is easily doable. i can easily recommend you a 2 ohm stable kicker zx1000.1 (1000RMS @ 2 ohms). kickers are decent amps, priced competitively, and will give you the performance you need.
http://cgi.ebay.com/NEW-07-KICKER-ZX1000-1-1000-W-MONO-AMP-REMOT-BASS-KNOB_W0QQitemZ180199795273QQihZ008QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
this one is dirt cheap and with warranty compared to what they are supposed to sell for (MSRP). once you get 2 DVC 2 ohm subs and the amps you are going to want a sealed box that meets the specs of the 2 subs together as far as space goes. hope this helps
p.s. do you still want some trunk space? if so you can get 1 12" IDmax from image dynamics (1000W RMS) and it will get plenty loud enough, plenty low, and blow you away. as before you want dvc duel 2 ohm. 1 cubic foot sealed box should be enough for that setup but that's up to you
DeLuXe24
DeLuXe24
CA
MSW Danny
