l7 making odd noise
ohhh i see well then idk
i know mine isnt bottoming out because if it was both would more than likely
how much airspace is yours built for
also wat electrical do you have for that sundown at .5,i was gonna run that but wanst sure how much electrical i was gonna need
well then i should be in the 145 range i am figuring since its ported in a box around 5.2net
but idk how that would go so well since its tuned to 33-34hz
wat do you think i would be around
also how much are you giving them with that sundown at .5ohms (how much does it put out at that ohms) and whats your voltage drop
what car are you useing. its alot harder to get a trunk louder then a suv. i know that im giving thim over 2000 just never tested them out as for the voltage drop have no clue im going to find all that out this week.
i have the setup in a truck 2001 f150 king ranch with the bucket seats in the back with the rear console i took the rear console out and got a bo to fit back there subs up port back
if you know wat kind of truck i am talking bout then u see wat i mean if not then idk if you ever seen a harley davidson f150 its the same design just different interior
yea i was hoping to be around the mid 40's so if i hit 145 i would be extremely happy
once i get my electrical up a lil better i am gonna get it metered right now i am getting drops to 13 so i want that to get up and then i will test
and if you are hitting 142 sealed in a small box i am ported i am sure i can gain at least 2-3db's
im going to build a new box soon with aero ports around 4 cu ft my trunk is very small. one of my friends has a altima with two 15 ported at 6 cuft with 4 4" areo ports hitting around 146.9 with one sundown 1500
Dropping to 13 volts isn't bad..
wtf are you talking about:confused:
well its around 12.7 with lights on at night at idle on full tilt on the song put on dropping to 12.5-12.7 and thats with no big 3 that should give me right at 13 volts and i plan to get a hc1400 or something bigger upfront
only got a lil gold duralast upfront i mean its rated at 750cca and 1000amps so its not that bad
king ranch
Banned
king ranch
fl
pimpinmex803
