l7 making odd noise
i played both subs seperate at low to mid volumes both are playing and i free aired the one sub that i was getting the sound from and i heard a sound but not the same sound the sound i heard free airing was like bottoming out i am pretty sure
this is some pics of the sub and a video at the very end of the vid around the 2:10 mark you can hear the slight noise i guess the rest of the video i didnt have the camera close enough
still waiting for the video to upload
what are the dimensions of the box and the port(s).
box is 33 high double baffle 28 deep and 13.5wide= 5.65 before subs or port displacement and the port is .16 so that drops to 5.49 and say both subs take up .20 drops to right around 5.2-5.3
internal is 30.75x26.5x12
the subs are mounted facing the roof and the port is facing the rear wall its on 6 inch aero tuned at 33-34hz
port length is 10.08 and thats with the flare as well the straight piece is only 9.08
so not sure exactly wat the subs displace so anywhere from 5-5.3 anywhere in there
yea only at high volumes and only on certain freqs most noticeable on the song blue berry yum, and 3 peat
but it doesnt look like the tinsel is slapping so idk i am just gonna play it until it gets worse where i can hear it without listening for it you know what i mean
i doubt 50 more watts is much considering i set gains with a dmm and they arent constantly seeing a true 800rmsand from a few things i read on here ported boxes can make the sub handle power better and can actually give the sub more than rated at times and its only 50rms more per sub
and wouldnt both be doing it and not just one
1. you my friend are retarded, ported boxes lower the power handleing as less resistance is held on the sub and it moves up and down a whole lot easier, sealed holds the pressure on the sub as it moves down, causing more resistance and more power handling, you obviously have no idea what you're talking about
2. you first day with your subs hooking them up you turned your gains all the way up and fed the subs the full 1664 without even easying them in???
3. weren't you the guy that wanted a custom glass enclosure to seperate the back window seats and you were looking for the 'coolest' looking sub regardless of performance to show it off in the sick glass 'box'???
deff not me i didnt care about how cool the sub looks
and they have been on 425rms for about 3 months so they have had time to break in and i am giving them 800rms a piece now so they should be fine many people feed their subs the rated power right out of the box and have no problems
why dont u go somewhere no one wants to read your comments
well i did read on here a discussion i cant find at the moment but was reading a ported box allows you to give more than rms since you can tune the box and something called a subsonic filter can fix too much excursion problems
king ranch
Banned
king ranch
fl
pimpinmex803
