l7 making odd noise
king ranch
Banned
i have 2 12's 08 l7's dual 2ohms i have them wired up to 2ohms to a zx1500 in a 5.2net tuned to 34hz box, today i hooked up them to the 1500 and the B.S. says 1664 so i set gains to 1600rms with a 50hz tone and dmm. so 56.5 is what i have them set at right now, and i have the subsonic filter switch selected on the amp.
I know i am giving them 800rms but i figured thats fine
Anyway only one of the subs makes a weird noise almost like its bottoming out it sounds like its hitting plastic or like something is in the way of the cone and making a scratching kind of noise its hard to describe, i will try to make a video tommorow.
what could this be and why is only the one sub doing it
is the tinsel rubbing the cone or wat
this is the first time ever heard it they have been on 425rms a piece for about 3 months and now they are on 800rms a piece and this is the first time i heard the noise
will that hurt the sub at all and is there anyway i can find out for sure thats it and fix it if possible or do i have to send it back to kicker
wanted to add i havent tried but could it be that i have the freq down at 50hz instead of 80 or wat
the subsonic filter is set at 25hz cant change that on kicker amps so should i bump up the freq or wat
wtf are u talking bout dude i have them wired right and put a dmm on it to test the ohm load its right at 2.3ohms
only thing i need to really do is rewire the subs with bigger guage wire right now i am using only 14 or 16 guage cant rember
if it's only coming out of one sub, then something is wrong with that sub. Not any of your wiring //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Unless one of the wire came loose on the other sub and it's dangling in the box? But i doubt it
king ranch
Banned
king ranch
fl
pimpinmex803
NorthFramingham
    Jun 30, 2026
