L7 Magnet size??
man thing be too huge man.. you know.. that big magnet what make the shit BEAT! thats why it be beatin so much harder than every sub on earth is the big chrome magnet!!!
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
it doesnt say in the tech manual im kinda surprised... but unless youre concerned abotu how much weight its taking up in your trunk then it really doesnt have any effect on performance. actually magnet size if often a misleading spec for people who dont know that weight doesnt matter. (like peak power)
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
magnet size doesn't dictate output.
x2, some manufactures have way too much magnet for the woofer...as long as you have enough to supply the woofer with what it needs, overkill, is just overkill.......
the magnet is as big as that one from that one time that i went over there and weighed it with a measurement thing. you know. that time.
honestly. that has absolutly NO bearing on how good the speaker is. so its a point that does not matter, and should not be compaired.
but yo my d0ooode had thi$ Wolefenmhagggg sub with thsi HUUGEGE A$$#$ magnet. SHIT BE BEATIN TOO HARD!!!!!!!111ONE!! so you yasll cant be knockin on them magnetzzz cause dudeS shit was TOOO crispy!!!!!@
people be looking errwhere when we roll in his whip with that GAIN AT MAXXX!@!@
Every speaker will have an optimal BL product, the field strength in the air gap multiplied by the length of the voice coil wire in the field.
If the BL product is too low, the speaker is electrically not very well
damped (which will result in a woofer with a high Qts). A bump in
frequency response and a level drop in midband efficiency may be the
result. If the BL product is too high, the speaker is electrically
overdamped (Low Qts woofer). A very high midband efficiency, but the
driver starts to roll of early.
An high BL product can be achieved in a number of ways: increase field
strength; or increase wire length in magnetic gap.
The increase in field strength is limited; so some manufacturers use
very thin wire for the voice coil, as such they can achieve a high BL
product with a low field strength (cheap magnet). Or they use an 8 layer
voice coil... needless to say that electrical power handling will
decrease enormously.
Long stroke woofers, having only a part of the voice coil in the air
gap, need a very high field strength to achieve a high BL product. Often
this means a big magnet as well...
Use magnet size as an indication, but as nothing more than that.
U n r e a L
U n r e a L
Matoaca -VA-
squeak9798
