L7 doesnt seem like its wanging as hard as I expected
Your head unit has a lot to do with the band and strength of the signal sent to the amp.
The only malfunction with the HU, however, is lack of ability to retain settings when turned off due to faulty wiring. I get the feeling that other than that the deck is operating normally just with the added PITA of having to reset everything each and every time it gets powered up. That inandofitself would create enough aggravation for me to get it wired correctly but to each their own, I suppose...
Thank you! Yeah it was a hassle at first but Im used to it over the past year or so...doesnt even bother me much anymore its like a daily thing to do when entering the car
I think what I need to do is build a very good box for SPL. Considering that I barely fit the box I made in the trunk now, go with a little different demensions.
it was the same way with the last head unit I had....with the POS system I had...I tried wiring it the correct way to get my memory to worka nd it wouldnt work... its the wiring on the car or something because im positive my wiring is right.
You already described it as wrong, how can you be positive it's right?
I mean right as in I wired the harness correctly the way it should be... wrong as in their is something else in a section of the car I dont know about that is causing the problem. So MY wiring is right, something else is causing it to go wrong.
Installed a head unit is really simple, you just match the wires
I haven't read through the whole thread but, about the red and yellow power wires for your head unit. I had the same problem in my car. Turned out I had a faulty fuse. Not a blown one, just a faulty one. So check and double check all of your fuses. Good Luck
No no... its enough for me... but my mind just keeps telling me that this thing can get louder, and to me their is no point to have this sub if you cant get it as loud as it can safely be. its like whats the point of having an L7 if your not going to max it out every once in a while
only thing i can tell you is its time to upgrade //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
lol I just got this setup like a week ago...I just think I need a better box...like acctually take my time and use everybodys advice on how to correctly construct a box. I think I will be 100% satisfied after that... right now im about 90% so its not like THAT big of a deal
Judging by the other thread where you just made your box, it is a possibility that the sub hasn't broke in yet.. give it a month and come back, I know my older CVR's took forever to break in with daily use.... Other than that, maybe you just had higher expectations????
best part about what he says...
hahahah let me guess..... another L7 owner with not enough bass.....
this, class, is what we like to call a fanboy with downsyndrome....
notice the ignorance....the idea that because he rides the short bus, he is better than everyone.... yet he probably drools on himself....
/your life
krisfnbz
krisfnbz
Frederick MD
Twistid
