L-Shaped Port - Slanted Box
where do you get this program? how much it cost?
the name is google sketchup, and its free
as some one already stated, i need to go off port area. i used BBP to modle my sub. that is it. i use this site to determin my port size(http://www.carstereo.com/help/Articles.cfm?id=31). take said port size and turn that into internal volume of the port.(LxWxH) long as your slanted port has the same volume. your fine.
also i used sketch up to determin my gross box volume. then sub track port volume(externail dimentiosn factoring in the MDF sides)
OK sorry for getting on everyones nerves but all I do the last 3 days is sketching boxes in Sketchup and messing around with BB6 and similar programs.
Now, I finally ended up in the box below. Given that the one RE calc suggests and this one are the same, I think this is the box to go.
If everything is right I'm going to get the cutout plans and start building it... Thanks for your answers and patience again.
also dude, get ride of all this 5/16 and shit. work with incraments of 1/8, but i usualy do 1/4. makes it way easyer. and this shit dosnt need to be spot on perfect!
I use MM when I build anything. It's a lot more linear and easier to comprehend... The Imperial system, you have to do all sorts of math in your head. For the Metric system, it's just like "I need to go up an increment, from 2cm to 21mm. DONE!"
DOOM_NX
DOOM_NX
Kozani, Greece
DOOM_NX
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
