kx2500 going into protect..
aaron7114
I got my kx2500 via UPS today from k4rts. I hooked it up and before I hooked up the subs I set the amp with a DMM. Hooked he subs up got in the car and turned up the head unit. Once I turned it up to where I set the amp the amp started kicking in and out of protection mode. My first thought was because I hooked it up at 1 ohm. So I unhooked one sub so I would be runnng it at 2 ohm. It did the same exact same thing at 2 ohm. I unhooked both subs and turned and I was able to turn the gain all the way up and everything and it wasn't kicking into protection mode. My speakers are wired correctly because it they worked just fine with my hifonics bx1605d at 1 ohm.
Any ideas? I am really upset right now.
Yeah whats the electrical system like on your car...
120 amp alternator.
Big 3 done with 2 guage wire
I was watching my volts on my cap and it stay in the low 11s.
I thought it might be my voltage too but I turn my heater up full blast and it still went into protect at the same spot.
aaron7114
aaron7114
Arkansas
aaronmiiller
BP1Fanatic
BP1Fanatic
