Fattylegend6spd
Hi there
I just got the 3 fuse distrubution block and the " konfused " ground block system from knuconceptz for my install. All my wiring is knuconceptz and i havent had any problems up to this point.
On my compression fittings, they arent tight even when screwed all the way in. I double checked the amount of sheath i cut off the wire, and even tried cutting more/less to see if that affected things. No such luck. The wires will spin in their so called compression fittings. The worst is the 8 guage, it spins freely like it was a some kind of bearing or something!
Do i need to add some tiny washers inside so that extra space will be taken up (then wire will be compressed on the end and fit tight)? Is there some trick to this? Very frustrating, seems like there might be a machining defect or something....
G
G
