Knu Conceptz Wiring
If you only have one amp on the power wire and that amp is fused at 120A you only need a 125A fuse (closest to 120amp) in the 0awg wire.
A 125A fuse is the safest size fuse for the application, but ANYTHING BETWEEN 125 AMP AND 350 AMP FUSE WILL PROTECT THE WIRE. The important thing to remember here is that fuses have delays in them, and the higher the fuse rating the longer it will take to blow, which could theoretically damage electronics in your car from the "crowbar" effect before the fuse actually blows. Depending on the capacity of your battery it could take several seconds for a 350A fuse to blow when shorted directly to ground!
I guess what I'm trying to say is If you're only worried about only protecting the wire go with a 350A fuse, BUT IF YOU WANT TO PROTECT THE CAR , TOO, DONT GO ANY BIGGER THAN YOU ACTUALLY HAVE TO (125amp). You can always get a larger fuse down the road if needed.
I agree to fuse for the wire however I was not aware that his amp actually had fusing at the amp...therefore I erred on the side of caution and told him to fuse for the equipment, not the wire. A lower amperage fuse is always better than a higher one...less chance of a blaze. If the amp has the fusing at the amp, then yes, I'd go with a 250 Amp fuse for the wire.
The amp has its own fuses tard //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif any other fusing is to protect the wire.
I did not look the amp up to see if it had fusing at the amp so I erred on the side of caution and suggested he fuse for the equipment, not the wire. Sorry to have upset you. //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
ABNgang
ABNgang
Carmel,Indiana
AlterEgo99
