knu CCA wire
Knu sells oversized wire... a lot of companies do. The 1/0 cadence CCA I have is equivalent to the 2/0 welding cable I used for my big 3. Twist the wire really tight and angle it when you put it in the ring terminal so only half of it goes in at once. Then, pinch the other half and fiddle its way into the ring terminal. It can be kind of a pain but it should go in eventually. If it doesn't, take some needlenose pliers, put them inside the ring terminal, and try to open the pliers up so you pull the terminal open more.
I'll have to try that. do KNU ring terminals readily accept KNU wire? I need some more ring terminals anyways, and to avoid the hassle I'd just order from them.
Max_Power
^ From a Hairdryer ^
Max_Power
Toledo, Ohio
SuperSaeYoung
