kinetik bank wiring.
Are you using the 16v Kinteik batteries? If so just wire the 4v post and the 12v in series and parallel the batteries together if you have more than one. If you are not using the Kinetik 16v than yes you can just use a 4v and a 12v wired in series. Or you can also use two 8v and wire those in series. I dont believe it matters too much which way you go about it as long as you end up with 16v.
no, i am using 2 kinetik 4-8v splits...series the batt to make a 12v batt and two 12v batteries.
the two 8v sections get wired in series. Each 12v batt gets wired in series with a 4v section.
The three sections of 16v then get wired in parallel for a 16v bank old-school.
I just wanted someone to look at my crappy drawing and see if the wires are in the right spot.
BLUE= jumper wires, RED=12v, BLACK=ground
should look like this from your pic though it looks like you have 2 left mods
on the pic where the red and black cross they DO NOT HOOK TOGETHER and where the green lines are shows 1 of the 3 pairs of 17.7 v terminals.
are both of the modded cells the same? one should be right biased the other left
upon closer inspection, they are biased....you're drawing makes it easy to grasp....
I could never lay them out end-to-end in the car.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
djman37
SOLID
djman37
DFW, TX
djman37
michigan born
    May 14, 2026
michigan born
    May 14, 2026
