Kind of an odd request
i think i have one BNIB...if i still got it, its yours for $20 or maybe trade gor car audio goodies...i'll check when i get home...i think its that antique creme color tho.
I got a wireless keyboard and mouse just the mouse is missing the piece that covers where the batterys go, just take a piece of tap and bam good go to
Rings? I've had to make them before because the factory speaker mount was plastic, and I've had to make them so the windows would clear the...
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
i see, good to know At least. that means i could squeeze out more air volume indeed. bit of a crude design but so far was thinking of roughly...
It sounds like the remote is wired to the interior courtesy lights. Those lights come on as soon as you remove the key from the ignition. Try...
ace_800
ace_800
Okinawa, Japan
Ninja Primate
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
