boom24
it says in your sig you're still waiting on your amps arrival
i had 1 in the past aand some lil basterd stole it......
you dont need any insane electrical. i did it with whats in my sig. you need a good alt, a couple good batteries, and some 1/0... which you should have anyway for an amp that big.Ya what kind of electrical system do you have when you run the zx all day @ 1ohm?????
I have ran a T2000bd @ .5 ohm and it did fine... It got pretty warm but it never went into protect.why would it be insane if it ran at 1 ohm? Thats like saying the fosgate t2000 would be insane if it did 0.5ohms. The amp is made for 2 ohms, if you wanna use it you get sub(s) that wire to 2 ohms. You guys are too caught up on amps that do 1 ohm. If your sub(s) final load is 2 ohms get the kicker if you need 1 ohm get the fosgate or even a sundown.One amp is not better than another cause its rated for a lower load. I actually prefer amps that do most power at 2 ohms or 4 ohms myself. Just for the record, many guys have ran the zx2500.1 at 1 ohm with no problems.
Mean Green 200A alt, Kinetik 1400 and 2400 under the hood, an extra battery or two in my tool box. 4 runs of 1/0 from front battery to amps, 4 runs of 1/0 from tool box to amps. On a burp I think my voltage drop went to about 12.8 or 13.Ya what kind of electrical system do you have when you run the zx all day @ 1ohm?????
