kicker vs. re
best spl
  • 12" Kicker L7
    Votes: 11 25.0%
  • 12" RE Audio SE
    Votes: 5 11.4%
  • 12" RE Audio SX
    Votes: 28 63.6%
  • Total voters
    44
I think you would see more out of the SX. Aren't the12" L7's only rated at 750 RMS. The SX's are 1000RMS so you can probably take advantage of that 1100 RMS from the Hifonics you will be running to it.
its going into a 99 mustang gt convertible and i want to have some room for other things. so im thinking my box isnt going to be anymore than 2cft and im going ported at about 33hz with the hifonics bxi1608d which will be giving it 1100 watts at 2ohms. will that box even fit inside the trunk of the mustang after being built? the opening is not very big at all for the trunk? anyone with a mustang and pics?
I have a 2cft box tuned to 32hz in the trunk my 00 mustang, they are the same as your car, it was a ***** getting it in though, and that video is of my trunk.
and if you haven't bought a sub why don't you get a d2 so you can run at 1ohm and get more power, or get the power for cheaper.
[quote
because if i buy another one that is 4ohm then i can run both of them at 1ohm off the same amp
either sub you get, your box will mean more decided on were you wanna go with the system. So don't let re or kicker fanboys cloud your judgement. Just get a custom box made, the sub Is only 25% of the car audio set up. But personally get some tens due to the space.
as stated before i plan on building a custom box at 2cu^ft after displacement tuned to 33hz
liljojo4711
liljojo4711
dallas
alex5857
