Kicker l7 10"
Yeah just make sure to scrape all the epoxy from the trim and sand it then put it on thick youll be good its been a year sinve I put it and its still holdin strong
Yup scratch the remaining epoxy sand it then lay it on thick its been a year and mines still going strong , oh and the kind I grabbed was a silver tube
Sorry its called amazing goop the amazing is written small and goop is huge over the whole front side call around your local store before you drive out most should have it grab the silver kind
844
Darkstar987
Darkstar987
Nj
Nutdawg651
