Kicker KX1200.1 amp
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif The KX1200.1 and the SX1250.1 are very different amplifiers.
The KX-series isn't equipped with the DSP built-in on the SX-series units.
Your not gonna get all the power out of that amp if the subs are 2 ohm.....I have the same setup except my subs are 4 ohm....wired down to 1 ohm which the amp is stable at and it still isnt enough for me and the woofers barely move.
true, you need two 4's....
now our new ZX1500 or ZX1000.1 will work fine, it's rated into a 2 ohm load. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
When its wired at 2 ohm its only getting 600 watts not the 1200 its capable of(probably more), Like Tracy said get the newer line ZX if you can afford it because they are stable at 2 ohm and if not look around for another amp:)
x2, plus the ZX1500.1 will have more power over the KX12001
liyahsbrother2
liyahsbrother2
New Orleans, LA
snb778
