Kicker CVR vs CVX
I know they have much more power but just wondering if the bass is a big difference? I have been told i would need to get a high output alternator is this true?
If i go with 2 12'' CVX they are 1500 watts max per sub and 750 rms per sub which would end up being 3000 watts max and 1500 rms. i have looked at the Hifonics Brutus BRZ1700.1D which the subs would be wired to 1 ohm but i don't really understand how that works.
473
963
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
elballz12
elballz12
Decatur, AL
Bettr n' Revrse
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
