KIcker Comp VR
(Now that $150 for a pair of 12s is much more in line with the pricing I thought was going on.
If you're willing to wait a few days for them to ship to you then you ought to get them from Crutchfield and save a few bucks on sales tax.
Additionally either myself or many other people on the forum could give you a referral code for Crutchfield and get you another $20 off to make it $130/shipped for a pair of 12s)
i live 20 min. from a CC so it hink im good but thanks man
Now that $150 for a pair of 12s is much more in line with the pricing I thought was going on.If you're willing to wait a few days for them to ship to you then you ought to get them from Crutchfield and save a few bucks on sales tax.
That's fine, dude. No biggie - I was just trying to save you another $25 or so plus they would ship them right to your door but either way it's up to you, certainly. It's your money after all. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
As far as the HiFonics amp? That should work just fine. Get the Dual 2 Ohm versions, though, and run that amp at 2 Ohms. The 1 Ohm output might be a bit much for a pair of CVRs...
Noob here //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It was suggested to me to try one of these subs. I have an open air SUV, with a pair of 6x9s, and a 12" 1.2 cuft enclosure behind the rear seat. With a single sub, I'm guessing that a single voice coil is all I need. I'm not well skooled in the dual setup. I'm currently pushing the single sub with my Coustic amp, because my Directed amp sort of got wet in a sudden thunderstorm //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Suggestions?
*edit* I'd eventually like to add a component system. Unfortunately the mids will be facing each other behind the front seats. Tweeters will most likely be mounted in the "A" pillars or behind me in the roll cage.
Suggestions?
When discussing a single voice coil sub Vs. a dual voice coil sub one isn't any inherently better than the other.
They will simply require different wiring methods when looking to find appropriate amplification for the sub(s) in question.
Ergo ~ If you have a single voice coil 4 Ohm subwoofer and are running only one of them - you know that your amplifier needs to output X amount of power at 4 Ohms to power it.
If you have a Dual Voice Coil sub and each coil is rated for 4 Ohms then it gets a bit more complicated. That particular type of sub by itself can be wired to either a final load of 2 Ohms with the coils wired in parallel or a final load of 8 Ohms with the coils wired in series.
When you add two dual voice coil subs together it becomes even more complicated for the average novice just getting started in the hobby.
Here's a link that should be saved in your faves if you're going to be a car audio enthusiast at most any level ~
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
It's a really handy reference guide. Certainly it doesn't cover all possibilities such as odd Ohm values like the 3 Ohm coils found on some JL Audio subs or the 6 Ohm coils used in some of Audiobahn's gear but for your average 2 or 4 Ohm, single or dual coil driver it's enough info to get you started. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Is there a comparison of single vs. dual voice coil subs?
Is there a real advantage? Might just easier to stay with the single voice coil for now. MY MTX Thunders aren't sounding as "crisp" as I would like. Just looking for a quality replacement for under $150 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
doyoshuffle5
doyoshuffle5
lowell, in
Mad Max
NorthFramingham
    Jun 30, 2026
