kicker box ?????
stetson_p99
i need a box for a kicker 12'' sub and dont know if a sealed is best or if ported is best any suggestions?????? also size of box ?
Sensitivity: 87.1 dB
Frequency Response: 20-500 Hz
Recommended RMS Power: 750W
Peak Power Handling: 1500W
Impedance: dual 4 ohms subwoofer wiring options
* Nominal Impedance [Zn], 4 ohms [per coil] ; * Resonance Frequency [fs], Hz 26.4; * Power Handling Watts, Peak (RMS) 1500 (750); * Total Q-Factor [Qts] 0.36; * Equivalent Volume [Vas], ft3 (L) 2.3 (65.4); * Outer Frame Diameter, in (cm) 12 9/16 (31.8); * Hole Cut-Out Diameter, in (cm) 11 1/8 (28.3); * Mounting Depth, in (cm) 6 5/8 (16.8);
stetson_p99
stetson_p99
OREGON
justflexin
BP1Fanatic
BP1Fanatic
