Kicker Amps. Vs. Rockford Fosgate Amp.
Both make great amps. It just depends on what you're powering at what ohms and what your budget is.
RF's sweet spot is at 1 ohm, Kicker is (mostly) at 2 ohms.
no way in hell is kicker better than rockford cuz rf amps r extremely underated and well thats just me...
Being extremely underrated makes not an amp good. RF just so happens to make good amps. But, like I said in the reply above, it just depends on the application.
912
tom4info
tom4info
Los Angeles, CA
profundus-sanus
