sxkicker89
i was wonderin if this amp is stable at 1 ohm.would be a pretty good amp for me to get lmk if it will do thanks
x2. If you have a ton of electrical upgrades, you may be able to do it.. but if this thing pulls up to 300 amps at 2 ohms, imagine the amperage it pulls at 1. Run it at 2 and be safe..it will break peoples faces at 1 ohm.
it will also break the bank in electrical upgrades.
Several of you who posted must not have had direct experience with the amp. You guys are so wrong. If you even did a search, several people do run it at 1 ohm.it will break peoples faces at 1 ohm.
300A is the fuse it comes with. I highly doubt it pulls 300 amps on 2 ohms. Check my post above....running on 90A stock alt and no problems. It is great with current.x2. If you have a ton of electrical upgrades, you may be able to do it.. but if this thing pulls up to 300 amps at 2 ohms, imagine the amperage it pulls at 1. Run it at 2 and be safe..
