Kennwood amp
mr_kebo
Audio Section........................................................................................................................................ KAC-X811DRMS Power Output (+B = 14.4 V, CEA-2006)
(4 Ω) (1.0 % THD+N) .....................................................................................................................................................................................................533 W
(2 Ω) (1.0 % THD+N) .....................................................................................................................................................................................................919 W
(1 Ω) (1.0 % THD+N) ..................................................................................................................................................................................................1016 WDynamic Power (+B = 14.4 V, CEA-2006) .........................................................................................................................................................................566 WOutput Regulation (+B = 14.4 V, CEA-2006).........................................................................................................................................under 0.2 dB (4 Ω)Signal to Noise Ratio (CEA-2006).....................................................................................................................................................................74 dBA (W/4 Ω)Signal to Noise Ratio (Bypass) (CEA-2006) .................................................................................................................................................74 dBA (W/4 Ω)Low Pass Filter Frequency (24 dB/oct.) ...........................................................................................................................................50 – 200 Hz (variable)Infrasonic Filter Frequency (24 dB/oct.)......................................................................................................................................................OFF / 15 / 25 HzPhase Inverter ...................................................................................................................................................................................0° (Normal) / 180° (Reverse)Band Reject Filter Frequency................................................................................................................................................................40 – 200 Hz (variable)Frequency Response (+0, –3 dB)..........................................................................................................................................................................5 Hz – 200 HzSensitivity (rated output) (MAX.) ............................................................................................................................................................................................0.2 VSensitivity (rated output) (MIN.) ............................................................................................................................................................................................. 5.0 VInput Impedance ...........................................................................................................................................................................................................................10 kΩ
What kind of power can i expect out of this amp my buddy just picked up for cheap. Also what is dynamic power?
Hoping to power 1 15" stock SSD
From what I find, its rated at about
500 watts RMS @ 4 ohms
900 watts RMS @ 2 ohms
1000 watts RMS @ 1 ohm
Should power a single 15 alright unless its one of those SPL monsters. lol
Peace, Lee
mr_kebo
mr_kebo
Huntsville, AL
btchn71
